01-11-2006 04:21 AM - edited 03-10-2019 01:50 AM
I am using ipsmc 2.2 on CiscoWorks VMS server and whilst in the 4.X signature configuration engine, if I try to open any of the parameters for sting.tcp engine I receive the following error:
Object loading failed. An error occurred while trying to load the list of contexts
Does anyone else have this problem?
01-13-2006 09:14 AM
I posted this issue recently in this post:
For me the error occures only when attempting to modify a signature in the Context of a group (i.e. the global group). I am able to tune signatures on a sensor level. However, it's still a bug.
I guess Cisco ain't going to fix this issue since the 4.x branch is unsupported in sep-06.
01-18-2006 02:55 PM
Try reimporting the sensor. This will read the meta files for the sensor and place it in the MC database. If the meta data is not in the sensor database, then you'll see this error.
Hope this helps.
01-19-2006 01:44 AM
Thanks for the tip. Unfortunatly it did not help, still unable to tune most signatures on group level.
01-20-2006 04:44 AM
i had redo the entire installation in order to resolve the problem but i did not restore the db. i recreated the configuration and all of the ajustments from scratch.....
02-01-2006 06:12 AM
I am still experiencing this error message even after a complete reinstall.
Is there anyway to check if the correct meta data files are installed?
The problem with the solution to re-import the sensor is that after that you are unable to globally manage the signatures from that device. i.e. A change in the signature parameters made at the group level on the vms will not be reflected on that imported sensor as the signature is owned by the sensor.
