Stupid IDS Question
SmithKJ
Yes, I know this is idiotic, but I'm not finding it in my book. Please don't flame me...
IDS 4215, I'm in the command line and have enabled an additional sensing port. It's working fine - how do I save the config change? wr mem is not so much working and I don't see a save option when I use "?" - any help would be greatly appreciated, thanks.
Kamal Malhotra
Use the following command :
copy current-config backup-config
HTH,
Please rate if it helps,
Kamal
5 Replies 5
Kamal Malhotra
HTH,
Kamal
Oi - I'm an idiot. Worked great - thanks!!
Hi Smith,
No problem and thanx for the ratings :-)
Kamal
mhellman
Level 7
Level 7
fwiw, while the "copy current-config" command is probably a good idea...it isn't equivalent to a "wr mem" on an IOS router. When making most changes via the CLI, you will be asked to "apply changes". If you say yes, the config is written. Now if the sensor is rebooted, those changes will be there.
mhellman
Level 7
Level 7
