Switch config for Inline Interface Pair
engineer467
Hello all
Am having a doubt here, so need your help.
I want to configure an IPS in inline interface mode. What I have is
internet rtr---->Switch----->outside intrface of ASA
Here, I want to monitor/inspect the traffic coming from the internet.
I am planning to connect the inline interfaces to the same switch.
What am not sure is what will be the switchport configuration for the inline interface pair?
Also, How the switch will forward traffic to the IPS and then IPS to the ASA?
Thanks in advance
..Abhi
5 Replies 5
engineer467
One more thing, there are no VLANs configured on the switch. Everything is in vlan1 by default.
rhermes
Level 7
Level 7
What are you using for an IPS, an appliance? an IOS IPS in the Internet router or the ASA?
If you want to feed the output of your IPS into the same switch as the input, you'll need to create two separate VLANS, one for the switch interfaces that are outside your IPS and the other for the interfaces that are inside your IPS.
interface Gi0/1
  switchport access vlan 10
switchport mode access
switchport nonegotiate
interface Gi0/5
  switchport access vlan 20
interface vlan 10
interface vlan 20
- Bob
Thank you so much for the reply Bob
I am using an IPS appliance here.
So both the interfaces of the inline pair will be in different vlans.
As i understand now, traffic enters from internet to the switch on port configured in vlan1(default).
The default gateway on the switch has to be the virtual interface IP of the inside of my IPS?
Please correct if I am wrong..
Your IPS appliance will bridge the traffic between the two VLANS.
Assign your VLAN ports like this:
VLAN 10
internet connection
Outside interface of IPS sensor
VLAN 20
Inside connection to your network
Inside interface of your IPS sensor
PLEASE put your sensor on the inside of your firewall.
- Bob
Naveen Kumar
Level 4
Level 4
Hello Abhishek,
just to add in this:
Cisco Intrusion Prevention System interfaces configuration guide:
http://www.cisco.com/c/en/us/td/docs/security/ips/7-0/configuration/guide/cli/cliguide7/cli_interfaces.html#wp1031719
