Trouble Installing license on IDSM-2
I got my license for an IDSM-2 that I am installing (used serial number of IDSM to get it). When I go to install it, whether via the CLI or through the web interface I am informed that the license in no good...
Here's the message from the CLI:
Error: setLicenseKey : The license key on the system is invalid.
Here's the output from the "show version" command:
pcsd-suth-ids# sho ver
Application Partition:
Cisco Intrusion Prevention System, Version 5.0(2)S152.0
OS Version 2.4.26-IDS-smp-bigphys
Platform: WS-SVC-IDSM2-BUN
No license present
Sensor up-time is 7 min.
Using 236765184 out of 1983660032 bytes of available memory (11% usage)
system is using 17.3M out of 29.0M bytes of available disk space (59% usage)
application-data is using 28.7M out of 166.8M bytes of available disk space (18
usage)
boot is using 40.5M out of 68.6M bytes of available disk space (62% usage)
application-log is using 530.5M out of 2.8G bytes of available disk space (20%
sage)
MainApp 2005_Mar_04_14.23 (Release) 2005-03-04T14:35:11-0600 Run
ing
AnalysisEngine 2005_Mar_29_16.33 (Release) 2005-03-29T16:45:11-0600 Run
ing
CLI 2005_Mar_04_14.23 (Release) 2005-03-04T14:35:11-0600
Upgrade History:
IDS-K9-sp-5.0-1.2- 14:00:00 UTC Thu Mar 17 2005
Maintenance Partition Version 2.1(2)
Recovery Partition Version 1.1 - 5.0(2)
Any ideas as to where to start? is there any chance that the license file could be no good? I double-checked that it was not modified after receiving it in e-mail...
Tim
Re: Trouble Installing license on IDSM-2
This turned out to be a 'bug' where the IDSM fails to accept a license if it is installed in slot 1. I moveed the module to another slot, as per Cisco TAC, and it accepted the license...
Yeah but i have a 5520 no additional slot. is there a new IOS I should load?
Derek, the above post is for IDSM-2 which is on 6500 switch platform.
You would have AIP module on ASA which is irrelevant to the bug that was found.
809
