10-02-2007 02:07 AM - edited 03-10-2019 03:49 AM
I installed a AIP SMM module in an Cisco ASA 5520 device.
After poweron the status and power leds on the module are ok.
When I am trying to access the module for basic configuring (by the ASA console), I get this message:
ASA5520# session 1
Opening command session with slot 1.
Card in slot 1 did not respond to session request.
Does somebody have experience with this issue?
Do I need an extra license to activate the AIP SMM module?
Thanks in advance,
Nico
10-02-2007 11:31 PM
Hello Nico, did you try resetting the module?
hw-module module 1 reset
Have a look at this link for more information:
http://www.cisco.com/en/US/docs/security/ips/5.0/configuration/guide/cli/clissm.html#wp1034193
Farrukh
10-10-2007 07:38 AM
Module was defective and is replaced now.
Thanks for your help.
Nico
