Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Unable to acess IDM 6.0 after upgrade on IDS4215
I've upgraded the IDS 4215 from Version 5.0(2)S152.0 to IPS-K9-6.0-3-E1. Now I can't logon to IDM 6.0. I could when the IDS was on ver5.0(2). I've attached the error I'm getting. I've followed the release notes checked the bios levels still no luck.
Any suggestions?
Silver
Re: Unable to acess IDM 6.0 after upgrade on IDS4215
To access IDM from ASDM, click Configuration > IPS.
You are asked for the IP address or hostname of the AIP SSM.
?If the AIP SSM is running IPS Version 6.0 or later, ASDM retrieves IDM from the AIP SSM and displays it as part of the ASDM interface. Enter the AIP SSM password and click OK. The IDM panes appear in the ASDM window. If the AIP SSM is running an earlier version of IPS software, ASDM displays a link to IDM. Click the link to launch IDM in a new browser window. You need to provide a username and password to access IDM
I've sorted the problem out. It was a java problem. You need java j2re-1_4_2_06
150
