Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Upgradation from IPS 6.2(1)e3 to 7.0(2)E3.
Hi All.
   Any separate license is required to upgrading os from 6.2(1)e3 to  7.0(2)E3 .
Pls find the show version of IPS.
sh version
Application Partition:
Cisco Intrusion Prevention System, Version 6.2(1)E3
Host:
    Realm Keys            key1.0
Signature Definition:
    Signature Update      S407.0                   2009-06-08
    Virus Update          V1.4                     2007-03-02
OS Version:               2.4.30-IDS-smp-bigphys
Platform:                 WS-SVC-IDSM-2
Serial Number:
Trial license, expires:   02-Mar-2011 UTC
Sensor up-time is 10 days.
Using 1408135168 out of 1983508480 bytes of available memory (70% usage)
application-data is using 36.7M out of 166.8M bytes of available disk space (23%
usage)
boot is using 39.7M out of 68.6M bytes of available disk space (61% usage)
application-log is using 533.0M out of 2.8G bytes of available disk space (20% u
sage)
MainApp          E-2008_OCT_16_16_24   (Release)   2008-10-16T16:40:57-0500   Ru
nning
AnalysisEngine   E-2008_OCT_16_16_24   (Release)   2008-10-16T16:40:57-0500   No
tRunning
CLI              E-2008_OCT_16_16_24   (Release)   2008-10-16T16:40:57-0500
Upgrade History:
* IPS-sig-S386-req-E3       15:15:25 UTC Sat Mar 14 2009
  IPS-sig-S407-req-E3.pkg   16:02:01 UTC Sat Jul 11 2009
Maintenance Partition Version 2.1(3)
Recovery Partition Version 1.1 - 6.2(1)E3
Host Certificate Valid from: 25-Feb-2008 to 25-Feb-2010
Appreciating your earlier reply.
AVS
1 REPLY
Re: Upgradation from IPS 6.2(1)e3 to 7.0(2)E3.
There is no license required to do software upgrades.However a valid License is required to install signature updates.
Farrukh
409
