Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Upgrade a sensor 5.0 -> 5.1
Is it normal when i upgrade a sensor IDS 4250XL from 5.0 to 5.1 the AnalysisEngine stops?????
1 REPLY
Re: Upgrade a sensor 5.0 -> 5.1
Hi .. please see the notes from the release
WARNING: The sensor may take up to an additional 25 minutes after final
reboot during the installation in order to complete initialization of
the analysis engine before monitoring will begin and the sensor can be
configured. DO NOT REBOOT THE SENSOR DURING THIS TIME. Doing so will
leave the sensor in an unknown state and may require that the sensor be
re-imaged.
I hope it helps .. please rate it if it does !!!
134
