11-18-2010 10:35 AM - edited 03-10-2019 05:10 AM
I want to upgrade the IPS module in an ASA 5510 and have a few questions. The AIP-SSM is running 6.2(1)E3 479.0 and I have a valid CCO account etc for this.
cheers
Solved! Go to Solution.
11-19-2010 03:53 AM
Let me provide some clarification on a few points:
2. You do not need to re-image the device using the .img file. You can upgrade the device, maintaining your existing configuration using the .pkg file. This is the recommended method for upgrading all of Cisco's IPS appliances/modules. The .img re-image file should only be used to restore the device to factory defaults.
5. Here are links for upgrading the sensor using a .pkg file. For upgrades via the IDM GUI:
For upgrades via the CLI:
Another point of clarification; the current releases of IPS software supported on the AIP-SSM-10 are (taking into account you are currently running 6.2(1)E3):
6.2(3)E4
7.0(4)E4
You can upgrade directly to either release.
Scott
11-19-2010 08:50 AM
You selected the file for the SSC-5 platform. It will not work on the SSM-10 platform.
In the download site you needed to have selected the "Cisco ASA Advanced Inspection and Prevention (AIP) Security Services Module " instead of "Cisco ASA Advanced Inspection and Prevention Security Services Card".
Then selecting the Upgrades link and 6.2(3)E4 you would have come to this file which can be used on the SSM-10: IPS-K9-6.2-3-E4.pkg
11-18-2010 11:38 AM
To answer your questions
1. Does the Software version on the ASA matter?
As long as the ASA is in 7.2.x or higher it does not.
2. When I look in software downloads < IPS there are .pkg and .img files. I want to upgrade to 6.3(3)E4. Do I have to re-image the IPS module?
3. As far as I know re-imaging will wipe teh device so I just reload the config after, right?
4. I presume I can apply any upgrades after going to E4?
5. Can you give me any links for this upgrade?
https://supportforums.cisco.com/docs/DOC-5668 shows how to do it with an CSC module. You will do the same thing but you will use the AIP image.
I hope it helps.
PK
11-19-2010 03:53 AM
6.2(3)E4
7.0(4)E4
Scott
11-19-2010 08:42 AM
ThanksGuys,
When I try to upgrade to IPS-SSC_5-K9-6.2-3-E4.pkg from the GUI and CLI I get "cannot upgrade the software on the sensor. This package cannot be installed on the SSM-IPS10 platform" I am downloading it from under the ASA modules section
This is the latest .pkg file available to me. Any ideas ?
11-19-2010 08:50 AM
11-19-2010 09:05 AM
I go to Products < Security < IPS < IPS Modules for ASA < and the only option is Cisco ASA Advanced Inspection and Prevention Security Services Card
Must be a link missing using the software download tool on the site. I followed your link and can see what I want
thank you
