upgrade ASA-SSM-10 via FTP
Hi all,
I am trying to upgrade an ASA-SSM-10 running version 5.1 software.
I have set up an FTP server using Serv-u and can connect to it successfully.
When I attempt to upgrade using the following command, I get the error below.
sensor(config)# upgrade ftp://cisco@10.40.11.8//IPS/IPS-K9-6.0-3-E1.pkg
The filename IPS-K9-6.0-3-E1.pkg is not a valid upgrade file type.
Continue with upgrade? []: yes
Error: execUpgradeSoftware : Connect failed
I have tried 2 FTP servers and receive the same error I have tried 4 upgrade packages and receive the same error.
Does anyone have any advice on how to fix this issue.
Thank you
Greg
1 REPLY
Gold
Re: upgrade ASA-SSM-10 via FTP
Your upgrade commands look correct. http://www.cisco.com/en/US/docs/security/ips/6.0/configuration/guide/cli/cliImage.html#wp1243115
I've had some problems with Serv-U in the past year or so. I had to switch to FileZilla to perform my last upgrade.
http://filezilla-project.org/
- Bob
1048
