05-19-2006 12:01 PM - edited 03-10-2019 03:01 AM
UPGRADING FROM 4.1 to 5.1. I know I have to got to 5.0 before I go to 5.1
I have tried to upgrade from 4.1 to 5.0 and am failing. I upgraded the Maintenance Partition to 2.1(2) as you can see from the show ver command output.
When I go to upgrade using the file IPS-K9-maj-5.0-1-S149.rpm.pkg i get the error messages to the console. they are included in the command line dump that follows..........
Cisco Systems Intrusion Detection Sensor, Version 4.1(5)S225
OS Version 2.4.18-5-phoenix
Platform: WS-SVC-IDSM2-BUN
Using 970657792 out of 1979682816 bytes of available memory (49% usage)
Using 5.1G out of 17G bytes of available disk space (32% usage)
MainApp 2005_Sep_01_21.30 (Release) 2005-09-01T21:30:35-0500 Running
AnalysisEngine 2005_Sep_01_21.30 (Release) 2005-09-01T21:30:35-0500 Running
Authentication 2005_Sep_01_21.30 (Release) 2005-09-01T21:30:35-0500 Running
Logger 2005_Sep_01_21.30 (Release) 2005-09-01T21:30:35-0500 Running
NetworkAccess 2005_Sep_01_21.30 (Release) 2005-09-01T21:30:35-0500 Running
TransactionSource 2005_Sep_01_21.30 (Release) 2005-09-01T21:30:35-0500 Running
WebServer 2005_Sep_01_21.30 (Release) 2005-09-01T21:30:35-0500 Running
CLI 2005_Aug_02_10.53 (Release) 2005-08-02T10:25:35-0500
Upgrade History:
IDS-sig-4.1-5-S225.rpm.pkg 14:40:27 UTC Thu Apr 20 2006
Maintenance Partition Version 2.1(2)
THESE ARE THE ERROS I AM GETTING DURING THE UPGRADE WHICH FAILES.
/signatures/[sig-id=11027,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11211,subsig-id=1]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11245,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11245,subsig-id=1]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11246,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11247,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11248,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11249,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11250,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=11251,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=12024,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=12025,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=12025,subsig-id=1]/engine/ -- the union does not have a member selected
/signatures/[sig-id=12026,subsig-id=0]/engine/ -- the union does not have a member selected
/signatures/[sig-id=12027,subsig-id=0]/engine/ -- the union does not have a member selected
Any help would be great!
gary price
05-25-2006 06:18 AM
The combination of tcp-reset on some UDP signatures in 4.x. was not invalidated. 5.0 is stricter and enforces this. It might be the best to disable reset for all signatures and then proceed with the upgrade.
06-14-2006 11:12 AM
done! Simply did application image for 5.1 worked great gprice
