Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Upgrading from v4.1 to v6.0
I have an IDSM-2 that I want to upgrade. Would there be a problem if I upgraded my IPS from 4.1 to 6.0, CONSIDERING that i'm willing to blow away any old configurations. Basically, I want to start from scratch on the IDSM with the 6.0. If that's the case, i'm assuming I can just go ahead and jump to install 6.0?
Jason
1 REPLY
Re: Upgrading from v4.1 to v6.0
Your question comes down to terminology.
An "upgrade" in IPS terminology involves the conversion of configuration from the lower version to the higher version.
The IPS 6.0(2)E1 upgrade file (the latest 6.0 version you should use) is: IPS-K9-6.0-2-E1.pkg available from this link:
http://www.cisco.com/cgi-bin/tablebuild.pl/ips6
BUT the IPS 6.0(2)E1 upgrade file can NOT upgrade a sensor from 4.1 to 6.0(2)E1.
Instead if you were worried about conversion of your configuration you would have to first upgrade to 5.0(1e). And then from 5.0(1e) you CAN upgrade directly to 6.0(2)E1 using the file I mentioned above.
But by saying that you are not concerned with conversion of your 4.1 configuration, then you open yourself to another alternative that we refer to as "System Re-imaging".
With System Re-imaging everything on the sensor will be wiped out (including configuration) and a fresh manufacturing image will be installed on the sensor.
System Re-imaging can be done to Any version (any version that has a System Image) from Any version.
There are no version requirements because it first erases everything on the sensor.
To do a System Re-image to 6.0(2)E1 you will need to download the 6.0(2)E1 System Image file specifically for the IDSM-2:
WS-SVC-IDSM2-K9-sys-1.1-a-6.0-2-E1.bin.gz
from this link:
http://www.cisco.com/cgi-bin/tablebuild.pl/ips6-cat6500-idsm2-sys
Follow these steps:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids13/cliguide/cliimage.htm#wp1031426
155
