9951 KEM on CME 8.5
epasqualotto
Hi, anyone have this phone and expansion works on CME 8.5? When I plug the expansion the phone say me the is disabled by the administrator but I don't know how to enable it.
Also in the SIP configuration I can't see any expansion to add in the type of the register pool.
Any suggestion?
Enrico
6 Replies 6
William Bell
Go to the 9951 device configuration page. Go down to the Expansion Module Information section. Under the Module 1 drop down list, select your KEM model. Click on Save and Apply Configuration.  You will also want to look at the phone button template assigned to the station to take full advantage of the KEM.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
We're using Cisco Call Manager Express, I don't have the "9951 device configuration page".
Enrico
Woops, sorry. My reading comprehension skills must have taken a dive!
I am not sure about how to accomplish this on CCME. My cursory search on CCO and the data sheet for the KEM do not show the KEM and CCME as compatible. Though, that isn't necessarily definitive.
HTH.
Bill
we have the "same" problem. We use 8961 phones and will install 1 KEM for the reception.
sh telephony-service
CONFIG (Version=8.6)
I know the KEM is working in SRST-Mode (other customer with CUCM 8.x and a VGW (2921) with SRST)
Hi ,
KEM is still not supported in CME environment.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
i see the CKEM on the roadmap for CME 9.1 wich should be released this year.
best regards
Franz
