Call Waiting on Rollover line not appearing
Abhishek Singh
Hi All,
Seems to be a bad day with all sort of issues
we have  specific lines for our vice president (s) at our org, what exactly is happening is that intermittently for some of them , the roll over lines ( line 2..line..3 of the same directory number ) are not able to show call waiting for an incoming call , i.e no incoming call notice on the phone screen , when the user is busy on his line.
I have increased the max call number from 2 to 8 and busy trigger to 4.. but to no avail.
Is there something else that can be tried ?
ccm 6.1 , phone model : 7962
Whatever level you reach getting better never stops -- Sachin Tendulkar
Chris Deren
Not sure if I follow, you mention rollover lines and busy trigger, these contradict themselves as if you need to use rollover forwarding you set busy trigger to 1 so that call can go to the next DN on the phone via call forward busy/CSS configuration.
If you set busy trigger to more than 4 then single line will get 4 calls at a time before rolling over, and all new calls will show up the caller ID if ring setting is set properly.
Chris
