09-02-2014 04:32 AM - edited 03-16-2019 11:59 PM
Customer has a few users who need to be able to mask their DDI when dialling out. They need to present their Non-Geographic number 0844.. This number bears no similarity to their DDI. How can I change what number is presented on a User by User basis? I've tried Masks but its not working.
Rich
Solved! Go to Solution.
09-02-2014 06:16 AM
Hi Rich.
You can create a dedicate route pattern with calling party transform mask for those users in a separate partition.
Than create a dedicated CSS to assign to desired users line.
Carlo
Carlo
09-02-2014 04:44 AM
Hi Rich.
With phone number mask selected in Route Pattern configuration, you should be able to present the caller DDI to the gateway.
Please post a debug ccsip message when user calls out.
Carlo
09-02-2014 05:39 AM
Have you tried using Calling party transformation? You'll need to set the CPT patterns in a separate partition and the CSS containing these partitions should be on the gateway. On outbound calls it'll be the gateway invoking the xformation. You can set the patterns specifically based on the calling DN.
09-02-2014 06:13 AM
I've created a test route pattern to my mobile with CPT and it works but I only want certain users to display the 0844 number. How can I restrict that for outgoing calls?
09-02-2014 06:16 AM
Hi Rich.
Carlo
Carlo
09-02-2014 06:26 AM
Thanks Carlo - worked a treat
