Cisco devices Supported for BE6K (CUCM 9.1)
rhyan.sanandres
Need to upgrade old version of CM(6) to BEk which will have CM 9.1. Now I want to know if the following devices can be supported in this new CM version.
Cisco SIP 3911
ATA 186
Cisco 7906
If there is documentation. I will highly appreciate.
Thanks!
2 Accepted Solutions
Jaime Valencia
All those can be configured, if the device itself is EOS/EOL, if you run into any issues with the device itself, there wont be support, as no FW is being developed to add functionality or correct anything.
java
if this helps, please rate
Jaime is correct (+5), Cisco never decommissioned any devices from being able to be used on newer releases, hence you still devices such as the VIP30, etc.  You will be able to use all of these devices just fine.
HTH,
Chris
Jaime Valencia
java
Hi Jaime,
Thanks for the reply. I know that there will be no support for the following devices as its already EOS/EOL. I just wanted to know if this will still run or supported by that new CM version.
HTH,
Chris
Thanks for the confirmation Chris!
