Communication with AD
Hi.
On CCM, 4.x, 5.x, 6.x and 7.x the communication between CCM and AD is safety or clear text?
If clear text, I think it, is possible to put safety in communication?
Peterson
Jaime Valencia
AFAIK we still do clear text as with windows version and is non-configurable
java
if this helps, please rate
java
Frederick is correct 5.x we enable under Directory settings, and we still need to install certificates.
In 4.x you need to run the plugin and enable LDAP over SSL.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dir_plugin/plug413.html#wp36626
You use a SSL certificate on the publisher for the connection between ccm and ad to secure connection.
If you are faimiliar with certificates its pretty easy.
For CCM 5.x and up, you can enable LDAPS (LDAP over SSL) which uses encrypted communication between the publisher and the AD LDAP instance.
