CUBAC queue association
milankopal
hello,
i've a cubac version 8.0.3.9 and i want to associate an operator with a defined queue. but when i select "user configuration" -> "operator management" -> then i select a suitable operator, there is no queue association area as should be (according the page 5-40 in cubac web admin guide).
any suggestion?
thank you
milan
Jaime Valencia
The ability to associate users to queues is only in CUEAC.
CUBAC doesn't have this capability.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
The ability to assign users to a CUBAC queue is now available in the latest version.
