Directory Number
nshoe18
I am trying to test our connection to a new SP and I am making a Directory Number for the test number they gave us. Is there a way that when I dial my cell phone I make it use that test number to dial out of the new system as opposed to my current running system?
Jaime Valencia
I'll assume this is CUCM 8.X
Configure a route pattern to exactly match your mobile and send it out via your new SP.
I'm assuming you already configured the necessary trunk so you can choose it under the route pattern.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I am actually using CM5.0(4). Do I setup a directory number for the test number they gave me or strictly a route pattern for the number?
You'd need to elaborate on exactly what is your requirement and call flow.
From your post what I understood is that you have 1 test phone number that can reach the PSTN and you want to use it to reach your mobile for testing.
If so, I already mentioned what needs to be done.
java
java
