Enable Second Line Automatic
wilsonsant
Level 6
Level 6
Hi Guys,
I would like know if it's possible enable second line automatic, because my Customer have more or less 2000 IP Phones and all are enable only one receive a one line. There are any procedure? If not,I will have that enable a one for one IP Phones. As information my Customer have a CCM 5.1.3
Wilson Santana
5 Replies 5
Jaime Valencia
if you mean accept two or more calls per line modify the maximum number of calls on the line to at least 2 and busy trigger to 3
java
if this helps, please rate
java
Hi Java,
Maybe I didn't had explain wright. The procedure manual I know, The that I would like know if is possible to do configuration automatic. For example, I program to change for next weekend.
Thanks ,
Wilson
yes, if you have used BAT in any linux appliance you should know you can schedule the jobs or run immediately
java
java
Hi Java,
There are any procedure to execute this activity? Therea are any link that you could inform to me?
Thank You,
Wilson
yes, BAT guide
Bulk Administration Guide, Release 5.1(3)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_3/5_1_3.html
bookmark this
http://www.cisco.com/en/US/products/sw/voicesw/ps556/tsd_products_support_series_home.html
ALL CUCM guides are in the above, you'll never have to ask for any links just look for the info there.
in any case just taking 30 minute and fooling around with BAT is more than enough to get a grasp of it without any guides
java
java
