FXS BUSY TONE
ahmedsalahomar
In my solution I have a 2 ports FXS VIC in 1751 router connecting through WAN to a 2 Ports FXO VIC in 1751 router , The system was working fine ,till the only ONE of the FXS ports started to give us a busy tone
what could be happened to make this situation?
could be this a result for a physical damage ?
this is the configuration for both routers , is there is any thing missed ?
Router 1 ( FXS ROUTER )
voice-port 2/0
connection plar 6510
voice-port 2/1
connection plar 6511
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 801
port 2/0
dial-peer voice 2 pots
destination-pattern 802
port 2/1
dial-peer voice 100 voip
destination-pattern 6...
session target ipv4:172.16.1.1
codec g711alaw
ROUTER 2 ( FXO ROUTER )
voice-port 2/0
timing hookflash-out 500
connection plar 800
voice-port 2/1
connection plar 801
destination-pattern 6510
port 2/0
dial-peer voice 800 voip
destination-pattern 8..
session target ipv4:172.16.1.2
codec g711alaw
destination-pattern 6511
port 2/1
5 Replies 5
paolo bevilacqua
If you reload both routers, does it helps ?
Hi Paolo,
Happy Holidays my friend! 5 points to you for all the great work you have done here this year. You are truly a wonderful asset :)
Cheers!
Rob
Hi Rob,
I cannot write too many times how the appreciation is mutual, and I'm only returning to the user community, a fraction of the many things I've learned from this forum, and from application and study.
Have you all a great Holiday Season!
Thank you for your replay
Yes I reloaded the routers but it does not work
any other steps.
Hi ahmed
Could you do "show voice call summary" and "show voice port summary"? please post the outputs here.
Thot
