02-16-2013 06:12 AM - edited 03-16-2019 03:45 PM
i want to know about CTI route point
i have one number which is CTI and i want to forword this number on mobile. and this CTI number associate with uccx call agents .when agents are not present and one agent want to forword his phone on mobile ..so he is not able to forward
so kindly let me know is it possible or not ? with reason
Solved! Go to Solution.
02-17-2013 07:16 AM
From what I gather you have a contact center and you want to redirect calls to outside in case the agents are not available, i.e. after-hours as forwarding single agent's DN independently is not supported nor would it work unless the agent is logged into ACD and call is delivered to him/her. SO, the supported way is to modify your script with logic to route to the external number when desired.
HTH, please rate all useful posts!
Chris
02-16-2013 09:23 AM
Dear
02-17-2013 02:33 AM
thx islam
02-17-2013 07:16 AM
Chris
02-17-2013 09:57 PM
Hi Chris ,
you are correct .So kindly let me know about script which we can use ..or if u have some image or ppt of scripting then share with me.
02-18-2013 07:43 AM
You can find some great examples in the CCX script repository here:
Cisco Unified Contact Center Express Script Repository 9.0(2)
HTH,
Chris
