02-10-2011 06:57 PM - edited 03-16-2019 03:23 AM
Hi all,
I make a call manager Lab for my study and can test call as follows.
1. ip phone to ip phone
2. ip phone to pstn moible
3. pstn moible to ip phone
However, I cannot make voip call to other voice gateway
1. ip phone to analog phone via ip
mobile phone ----------- PSTN -------- voice gateway1 ------------ switch ------------- call manager 7.0
------------- ip phone
------------- voice gateway2 ----------- analog phone
Setting in call manager
Region : G711
Locaion : unlimited
Could anyone know why I can't make voip call from ip phone to analog phone via voice gateway2 ?
Thanks in advance
Leung che Man
Solved! Go to Solution.
02-11-2011 03:44 PM
In the Gateway page in the Call Manager please ensure that
The Wait For Far End H.245 Terminal Capability Set is NOT checked
This is checked by default from CUCM version 8 onwards
also in the VG1 ensure that you have the following commands
global conf# voice service voip
conf - voice)# allow-connections h323 to h323
Thomas
02-10-2011 08:50 PM
You'll need to take detailed CCM traces during the entire failed call attempt from all the nodes in the cluster. This will provide you information on whether or not the call is making it to the CUCM server to signal the other end to ring and audio setup.This will be the only way to confirm/deny what exactly is occurring at this point.
Ryan
02-10-2011 11:16 PM
I guess the analog phone must be connected to an FXS port on the voice gateway 2. Is the FXS port MGCP controlled or H323 controlled? Have you added gateway to the CUCM? If its MGCP is it registered to the CUCM? If its H.323 have you added the dial-peers on the H.323 gateway?
Post your reply here in order to get a clearer picture of your issue.
Hope that helps
Nitesh
PS:Pl rate helpful posts
02-10-2011 11:37 PM
Hi Nitsinha,
They are H323 gateway. Both voice gateway 1 and 2 have dial peer.
Voice gateway 2
voice-port 0/0/0
station-id number 71
voice-port 0/0/1
dial-peer voice 10 pots
destination-pattern 7.
port 0/0/0
forward-digits 0
dial-peer voice 20 voip
destination-pattern 84.
session target ipv4:10.34.195.222
Voice gateway 1
voice class codec 729
codec preference 1 g729r8
codec preference 3 g711ulaw
codec preference 4 g711alaw
dial-peer voice 1000 voip
description ** To CCM7 **
voice-class h323 1
session target ipv4:10.34.18.96
dial-peer voice 99 voip
progress_ind setup enable 3
voice-class codec 729
session target ipv4:10.34.195.221
dtmf-relay h245-alphanumeric
Call from ip phone 841 to analog phone 71 via ip
nshk-cme#sh call his vo com
298 ORG T0 g729r8 pre- VOIP P71 0.0.0.0:0 D2F
297 ANS T0 g729r8 pre- VOIP P841 0.0.0.0:0 D2F
Total call-legs: 2
nshk-cme#sh call his vo b
dur hh:mm:ss tx:
IP
media inactive detected:
long duration call detected:
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 2
Call agent controlled call-legs: 0
Total call-legs: 2
10D5 : 298 180551560ms.291 +-1 +12170 pid:99 Originate 71
dur 00:00:00 tx:0/0 rx:0/0 2F (no resource (47))
IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long dur callduration :n/a timestamp:n/a
10D5 : 297 180551550ms.292 +-1 +12190 pid:1000 Answer 841
nshk-cme#
Leung Che Man
02-11-2011 12:08 AM
So if i got your call-flow correct, it is
Ip phone----CUCM----Voice gateway 1----ip-----Voice gateway 2----fxs---Analog phone
I see that you have
voice-port 0/0/0
Can you try adding the command number 71 under the voice-port 0/0/0 and try a test call again.
Hope that helps
Nitesh
02-11-2011 12:33 AM
Hi Nitsinha,
The call flow is correct. I can't add 'number 71' under voice-port 0/0/0. This commnad is not acceptable. I got the 'no resource (47)' in the voip call. Is it related to the codec mismatch ?
Leung che Man
02-11-2011 12:50 AM
destination-pattern 71
port 0/0/0
forward-digits all
make these changes and try...
02-11-2011 01:23 AM
@ Thomas- how will forward-digits all make a difference here? AFAIK the analog phone does not know the number 71. Hence sending the digits to the phone should not make a difference.
@Leung- Try using G711 codec for the call. I dont think the codec would be making a problem here. On which gateway do you see the no resource error? Is the call even hitting gateway 2? try running 'debug voip dialpeer' on both the gateways and check whether the correct dialpeer is getting matched.
Make sure that the FXS port to which the analog phone is connected is working fine. Lift up the handset of the analog phone and check for a dial-tone.
Post the output of debug voip ccapi inout for a failed call.
Hope that helps.
Nitesh
02-11-2011 02:28 AM
Hi Nitesh,
I can confirm the dial peer for both VGs are correct. I make the setting to G711 codec to the dial-peer in VG1
voice-class codec 711
After enabling the 'debug voip ccapi inout' in both VGs, I make a call failed. Please find the attached output for your reference.
Leung Che Man
02-11-2011 03:00 AM
Sorry for the misinformation because i saw that the no resource error is normally because of codec mismatch.
CC_CAUSE_NO_RESOURCE = 0x2F | no resource. (47) 1 |
1 This issue can occur due to a codec mismatch within the H323 setup, so the first troubleshooting step is to hardcode the VoIP dial-peers to use the correct codec.
Can you try making an inbound dial-peer on vg1 and ensure that the call leg from CUCM to vg1 is g711 as well. Try a test call. Make sure that you use g711 throughout the call from the IP phone to vg2. In the meantime i will try that out at my end.
Hope that helps
Nitesh
02-11-2011 03:44 PM
Thomas
02-12-2011 06:41 AM
Hi Thomas,
After I uncheck 'The Wait For Far End H.245 Terminal Capability Set', I can make the call from ip phone to analog phone. By default, this setting is checked, Can I know the function of uncheck the setting ?
Anyway, It is working now. Thanks everyone help me to solve the problem.
Leung che Man
02-12-2011 09:46 AM
Hi Leung,
Voip to Voip G/W (CUBE) will not initiate the TCS negotiation with CUCM. The real truth is that it depends on the signaling on the other side of CUBE. If that device initiates the H.245 negotiation with CUBE, CUBE will reciprocate that on the other side towards CUCM. Where you really run into trouble is when you have two CUCM boxes(your scenario) talking with this checkbox enabled. They will both halt waiting for the other side to initiate a H.245 session
This problem did not happen earlier because upto 8 the check box is by default unchecked.
This is required if the other end is a Non Cisco Call Manager(eg. Avaya) we need to wait for the codecs supported by other end and then select one and reply
Thomas
02-12-2011 04:13 PM
To my understanding, when you have "wait for far end TCS" checked implies that:This check box specifies that Cisco CallManager waits to receive the far-end H.245 Terminal Capability Set before it sends its H.245 Terminal Capability Set.
Call could also fail if
call manager sends empty capability set to the h323 endpoint which it does not support.
times when u could run into issues are when
h323 terminal does not support empty capability set ie. IOS running h323 version 1 . thus call fails
Check you IOS version it should be greater that 12.2(46)
refer the following links
