11-10-2015 02:42 AM - edited 03-17-2019 04:51 AM
We have one user with 9971 Desk IP Phone and Jabber for Android on Shared Lines ( Extension 1001 for both ) associated to single user.
1. How can i configure in such a way that jabber for Android will ring only after 2 rings on Desk Phone (9971) ?
2. Also just to clear some doubts , can i add this Jabber Android ( with shared line ) as my Remote Destination device for Mobility ?
Solved! Go to Solution.
11-10-2015 03:04 AM
AFAIK, you can't achieve either of the requirement.
1. With shared line, it's forking to all lines and there is no provision to add delay between the lines.
2. Remode destination number seems should be external number only and can't be internal DN.
- Vivek
Please rate useful posts.
11-10-2015 03:04 AM
- Vivek
11-10-2015 05:56 AM
Hi Vivek , Thanks alot for updating.
As you have mentioned Remote Destination should not be an Internal Extension , that means it should not be even in Translation pattern . Right ?
Can i achieve this by "Move" feature ?? How does Move Differes from Remote Destination ??
