06-26-2007 08:31 PM - edited 03-14-2019 10:17 PM
we could define two same dial-peer (only ip address is different) to create redundancy if the 1st ip address is not responding.
if we apply max-conn=2 to each dial-peer, the incoming connection will switch to the 2nd dial-peer if the max-conn for 1st dial-peer is reached. That is, 4 max connections are allowed.
we want to limit the max-connection to 2 but we also want to have backup ip addresses.
dial-peer voice 19150 voip
translation-profile outgoing my_profile
preference 1
max-conn 2
destination-pattern 51189150
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.1.25
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 19151 voip
preference 2
max-conn 2
destination-pattern 51189151
voice-class codec 1
session target ipv4:192.168.1.26
no vad
pls kindly advise.
06-26-2007 10:58 PM
If this is a pure CME or H.323 setup, you will need a gatekeeper to provide call admission control.
If your other end is CallManager, you can use locations to manage the maximum number of calls the CallManager will accept.
Aaron
Please rate helpful posts...
06-27-2007 01:47 AM
Can't you set max-connection on the incoming DP pots ?
