05-10-2010 05:22 AM - edited 03-15-2019 10:41 PM
I would like to know how many simultaneous calls a single FXO and E&M Port supports. I understand both can be used to do trunking, I did some research but unable to find the max simulatenous calls limit on each of these two ports. Any document explaining this is highly appreciated.
Thanks in advance,
inner_silence
05-10-2010 05:31 AM
One port, one call.
Two port card, two calls.
Aaron
05-10-2010 05:31 AM
Each port type supports one concurrent call. If you need more th
an that you need to use a T1/E1 type circuit.
