03-08-2015 07:06 AM - edited 03-17-2019 02:14 AM
Hi Folks,
I am trying to migrate my CUCM 7.1 to 10.5.1 using PCD 10.5. Now during installation of CUCM 10.5 i have found attached error. I have searched cisco support forum and i have found one of enigneer has faced this issue due to UK dialplan but in my scenario there is no Dial Plan installed.
Solved! Go to Solution.
04-16-2015 12:51 AM
Gents,
Sorry for late update. I have successfully upgraded the CUCM using PCD. I have tried it on another server i.e. BE7k series and didn't face any issue there. Don't know what was the problem in first server.
Any way thank u all for your support.
03-08-2015 10:07 AM
Hi Sheraz,
Just refer this link if it helps as u have said no UK Dial Plan are configured.
Further,I was checking the attached snapshot which shows version 9.0.1.10000-37[9.0(1)] but your are referring to 7.1 in subject.
regds,
aman
03-09-2015 03:11 AM
Hi Aman,Sheraz,
Attached is genric. Install logs will be right start to look at or Open Cisco TAC case to help review them.
Refer below link captures few other known issue which you might encounter while migration or upgrade using PCD
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118790-probsol-cucm-00.html
Mohammed Noor
03-09-2015 03:32 AM
Thanks for sharing the link[+5]
regds,
aman
03-09-2015 04:58 AM
Yw..! :-)
04-16-2015 12:51 AM
Gents,
03-10-2015 01:53 AM
Hi Aman,
Thats my Lab but originally i have to upgrade from 7.1.5 to 10.5 using PCD. In my lab with 9.01. nothing is configured like UK dial plan or any thing it contains just basic config thts it.
03-10-2015 03:23 AM
Hi Sheraz,
can u run the command in PCD file get install /install.log to get the logs ?
regds,
aman
03-10-2015 03:57 AM
03-10-2015 04:42 AM
are u using CUCM restricted or unrestricted on 7.1.5 and also what is CUCM 10 [RSTor UNRST]?
03-10-2015 07:23 AM
Hi Sheraz,
Check if your running this box in Grace Period, If so please contact Cisco tac to apply workaround of below defect.
CSCtb86875 Upgrades are prohibited during License Grace Period
HTH,
Mohammed Noor
