questions on clocking on 3700
e-chuah
Hi..
I hav a Cisco 3700 with two NM-HDV (one E1 port in each NM-HDV). The NM-HDV is connected (back-to-back) to two Cisco 2800.
If each E1 port is configured to obtain clocking from the line and "show network-clocks" shows that the C3700 router is using the backplane as the clock reference. Will there be any potential clocking issue?
Do i need to configure "network-clock-participate" ? The default is "no network-clock-participate"
Any comments greatly appreciated.
EW
paolo bevilacqua
Hi, do "show controllers e1". If you see any slips, than you clocking setup is not right.
