Separating clients in Call Manager 7 multi-tenant configuration
brife
I have a client sharing a call manager with another company. Does anyone know how to separate the two companies so that they have separate local directories?
I think the only solution to use some third part application.
You would need to write down custom directory scripts per company and then subscribe the phones from each company to the right one.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
