TSP 8.6 and Windows 2012
Hi there,
is TSP 8.6 64 bit version supported on Windows Server 2012 or any plan for this to be ?
Christian Bongiovanni
coCEO and CTO
Imagicle SpA
7 Replies 7
Harmit Singh
Hi Christian,
As per documentation, it isn't supported for vesion 8.6:
Supported Windows Platforms
All Windows operating systems support Cisco TAPI. Depending on the type  and version of your operating system, you may need to install a service  pack.
Windows 2008 Server R1
Windows XP SP3
Windows 2003 Server R1
Windows 7 (32-bit)
Windows 7 (64-bit)
Windows 2008 Server R2
Note Windows 7 (64-bit) and Windows 2008 server R2 require native 64-bit Cisco TSP client. For more information on availability, see http://developer.cisco.com/web/tapi/blogroll.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/tapi_dev/8_6_1/installation.html#wp150836
HTH.
Harmit.
Yes.
But as release notes of TSP 9.0 do not include support of Windows 2012 as well,
which are the plans for new Microsoft OS (Windows 8/2012) TSP support ?
Chris
Hi Christian,
Let me check this internally with the Dev team and see if there is a roadmap for both Windows8 and 2012. I will revert back once I get this info.
Harmit.
Just to give Harmit an escape clause here: roadmap information usually requires a NDA and is not public. As such you typically will not get answers to "when" questions on the public forums. I typically refer these questions to your Cisco AM/SE or the Collaboration User Group (which requires NDA signature to join).
Thanks Jonathan for pointing that out! Much appreciated! I agree with your school of thought, that is the ideal process to follow. +5! :-)
Harmit.
Hi Jonathan, Christian,
Just to add, I found a similar thread on CSC:
https://supportforums.cisco.com/thread/2182948
Harmit.
Windows 8 & windows 2012 is supported with CUCM 10.0.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/tapi_dev/10_0_1/CUCM_BK_TB35670B_00_tapi-developer-guide_chapter_0100.html#CUCM_TP_REB2D416_00
Supported Windows platforms
  • Windows 2008 Server R1
  • Windows XP SP3
  • Windows 2003 Server R1
  • Windows 7 (32-bit)
  • Windows 7 (64-bit)
  • VMWare
  • Windows 2008 Server R2
  • Windows 8 (32-bit)
  • Windows 8 (64-bit)
  • Windows 2012 Server
I don't think they will add this support for CUCM versions prior 10.0
BR
Franz
