04-24-2013 01:05 PM - edited 03-16-2019 04:59 PM
Hello everyone. I am facing an issue right now. The last weekend we upgrade our customer cucm cluster.
The cluster has 7 servers but finally we were able to upgrade 5 of the 7. 2 of them failed. I remove the servers from the publisher and turn them off. We need to reinstall the two servers but we do not have the bootable media at wich the cluster finally is working now. I am wondering if it is possible to install a 7.1.3 or another cucm version and after that upgrade to 8.6.2.22900-9.
Does any one has done this.?
Solved! Go to Solution.
04-29-2013 01:08 PM
Great, please mark the question as answered, unless you have further questions.
Chris
04-24-2013 01:58 PM
You can perform upgrade during the install, so obtain bootable media that is directly upgradeble to 8.6.2.22900-9, during the installation you will be asked if you want to perform an upgrade, answer yes and use the 8.6.2.22900-9 version.
HTH,
Chris
04-24-2013 02:23 PM
Thank you for the answer.
Do you know if this can affect the normal operation of the cluster?
04-24-2013 02:25 PM
Yes, as of CUCM 8.6 adding new servers to the cluster will cause all phones to reboot. Also, keep in mind that version 8.6 requires upgrade .cop for Red Hat refresh, so you will most likely need any 8.6 bootable version to start with.
HTH, please rate all useful posts!
Chris
04-29-2013 11:47 AM
The phones that will rebooted are all the phones registered to the other servers? .
Eventhough this servers will not have any phones registered on them?.
And if this reboot happen at what time do this will?,
Regards.
04-29-2013 12:04 PM
No, all phones. Check out release notes:
When you add a new node to an existing cluster, all phones that are registered to the cluster are reset
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_5_1/cucm-rel_notes-851.html#wp1957141
Chris
04-29-2013 12:27 PM
Thank you for your help.
04-29-2013 01:08 PM
Chris
11-19-2014 03:39 PM
Hello Chris,
About this bug, are you aware if fix applied in any release? Cisco never stated about the fix on which release. I want to understand ,is this going to be the case of reset everytime we add subscriber? Even if we upgrade 9.1.2?
https://tools.cisco.com/bugsearch/bug/CSCub12922/?reffering_site=dumpcr
