0x80af Resource unavailable, unspecified (Cause=47) Out calls
Hello.
I have a problem with outgoing calls. To call any destination in the PSTN calls set a tone and cut.
Making sure the debug problem in realaciona cause = 47 and 0x80af Resource unavailable, unspecified. That according to the documentation I have read is related to problems of codecs.
How I can check if the codecs are installed on the GW?
The DSP card is damaged? (PVM)
Any idea?
Regards.
show voice call command status codec shows no!
CallID     CID  ccVdb                          Port        Slot/DSP:Ch     Called #                Codec    MLPP          Dial-peers
0x97       3631 0x22C08E18     0/0/0:15.31      0/1:1                *0999135052       None        2/1
0x98       1208 0x22C08E18     0/0/0:15.1         0/1:2                      2602                  None      1/2
2 active calls found
Start by checking your config
Start by checking your config and make sure you're sending G711 to the GW, or have an xcoder allocated if you're sending a low BW codec.
java
if this helps, please rate
www.cisco.com/go/pdi
 Hello. Thanks for your
Hello.
Thanks for your answer.
How I can verify that?
VIP Super Bronze
Send us the ff: sh rundebug
Send us the ff:
sh run
debug voip ccapi inout
debug isdn q931
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
 hello.   attached files
hello.
Regards!
VIP Super Bronze
Looking at the logs, the call
Looking at the logs, the call disconnect is scoming from the CUCM side. We can see that the call leg 454 (which is the inboung leg from CUCM) is sending a disconnect to the CCAI process on the gateway
Mar 13 13:25:45.818: //454/0099FFD90C00/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x22705790, Call Id=454
Can you try the following: (addd the following to your gateway)
conf t
dial-peer voice 3 voip
voice-class codec 1
incoming called number .
dtmf-relay h245 alpha-numeric
no vad
If it still doesnt work then configure the ff and send us the logs..
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
<Enable debugs, then test again.>
debug h225 asn1
debug h245 asn1
<Enable session capture to txt file in terminal program.> (such as Putty)
then do the ff:
terminal length 0
show logging
Attach the logs
VIP Super Bronze
Also send the ouput of Show
Show voice dsp voice
  atacched file!. regards
  atacched file!.
regards
Hi I made the changes you
I made the changes you mentioned and not run.
Incoming calls also fails. Strangely, if the IVR answers Ok, but when the call is cut redirigue annex.
I did a test in the GW: Delete the SRST mode and configure a CME, add a CIPC connected directly to GW and calls work OK either incoming and outgoing. By tracking the show voice call status call the codec used is G711ulaw, however when the call comes from CUCM in the codec says "none".
regardss
VIP Super Bronze
What is your call flow like?
What is your call flow like? Can you describe it for us? Can you also post the full debug?
Hello. Thanks for your answer
Hello.
   the flow is:
IP Phone or CIPC -----> CUCM 9.1 -----> GW PSTN with E1.
 I attached sh GW and Debug  voice ccapi inout
Could you try applying voice
Could you try applying voice class codec command under dial-peer 2 and check the behavior please?
//Suresh Please rate all the useful posts.
Hi. Apply the command,  but
Hi.
Apply the command,  but still the same problem
The GW and the phones are
The GW and the phones are under same device pool? If they are in different device pool, could you please crosscheck the region config and make sure they use G711 codec?
  are in the same device pool
are in the same device pool....
Please collect the CUCM
Please collect the CUCM traces & the below debugs for a test call
debug h225 asn1
debug h245 asn1
debug voip ccapi inout.
Please include the calling, called numbers & show run from GW as well and ensure you have the test call successfully captured in the ccm trace files before uploading it here.
Hi. Attached files. the annex
Hi.
Attached files.
the annex number is 2669 and the external number is  90999135052 (+56999135052, movil)
thanks you.
regards
VIP Super Bronze
From the logs,CUCM is not
From the logs,
CUCM is not sending any h245 negotiation to the gateway. Is there a firewall between CUCM and the gateway? Can you send us detaile CUCM traces? Please seacrh on the forum on how to use RTMT to collect cucm traces
shall we try unchecking 'Wait
shall we try unchecking 'Wait for Far End H.245 Terminal Capability Set' in the gateway configuration page?
VIP Super Bronze
No, Suresh that shouldn't be
No, Suresh that shouldn't be needed in this scenario. We need to see what CUCM is saying, then we cna get a clearer picture
 help me how to do the traces
 help me how to do the traces in RTMT?
VIP Super Bronze
 The link below shows you how
The link below shows you how to do this..
https://supportforums.cisco.com/document/126666/collecting-cucm-traces-cucm-862-tac-sr
Enable the trace and do another test call..Then collect the traces and send to us.
Hi. Atached trace files RTMT.
Hi.
the call number out is 9.0999135052 (0999135052)
IP GW with problem : 10.203.124.189.
 updated: I write the dial
updated:
I write the dial-peer vocie 2 voip  the "codec g729r8" command or any codec and do a show run command does not save.
(config-dial-peer) # codec g729r8
(config-dial-peer) # do show run
dial-peer voice 2 voip
  preference 1
  destination-pattern 2 ...
  session target ipv4: 10.203.120.157
  dtmf-relay h245-alphanumeric
But if you save the voice-class codec command 1:
  preference 1
  voice-class codec 1
any idea?
638
