1 FXO port -- 2 analog lines
Hey guys --
Is it possible to terminate two analog lines into one FXO port? If so, is there any extra configuration needed on the gateway?
Let me know.
Thanks.
Re: 1 FXO port -- 2 analog lines
I haven't tried it, but I suppose you could use a splitter to accomplish this. Obviously, with only one port, only one line could be active at a time.
Brandon
So the answer is no, we need both lines active at the same time. Just to add, we will terminate four pins into the cable.
Thanks for the quick response.
Correct. A single FXO port can only terminate 1 connection at a time.
Brandon
Thank you sir.
111
