10 second delay on analog phone on VG224
Good morning all!
I have two analog phones connected to a VG224 which then connects to a CME (v8.1) system.
The phones are working, but when I pick up the handset and dial an internal or external number, there is approximately 10 seconds of "dead air" time before I hear the other phone ringing through the connection.  Also, when I have an IP phone call either of those analog phones, as I lift the handset I hear the tones from the dialed keys and then I'm connected to the caller.
I'm pretty sure this is related to the dial-peer config, but not sure exactly what I need to adjust to fix this.
Here's the appropriate config snippets from the CME:
dial-peer voice 1517 voip
description LL Lobby Phone
destination-pattern 1517
modem passthrough nse codec g711ulaw
session target ipv4:10.62.88.9   (VG224 IP Address)
voice-class h323 1
codec g711ulaw
fax rate disable
fax protocol none
no vad
dial-peer voice 1518 voip
description 1st Floor Lobby Phone
destination-pattern 1518
voice-class h323 1
codec g711ulaw
fax rate disable
fax protocol none
no vad
voice-gateway system  1
type VG224
mac-address E8B7.487A.4200
voice-port 0-23
create cnf-files
And from the VG224:
dial-peer voice 1000 voip
description outgoing calls TO CME
destination-pattern .T
voice-class h323 1
session target ipv4:10.62.88.1
codec g711ulaw
fax protocol none
no vad
dial-peer voice 1001 voip
description incoming calls From CME
voice-class h323 1
incoming called-number .
codec g711ulaw
fax protocol none
no vad
dial-peer voice 111 pots
port 2/10
forward-digits all
dial-peer voice 112 pots
port 2/11
forward-digits all
Any help will be greatly appreciated.
Thanks!
Kevin
1 ACCEPTED SOLUTION
VIP Super Bronze
It's because dial-peer 1000 on the VG224 is waiting for more digits. You need to be more specific to rule it out for four-digit extensions. For example, a destination pattern of 9.T would at least limit it's use to off-net calls. In that case off-net calls fro mthe FXS port would still wait for the inter-digit timeout though.
Depending on your country you probably do not want to use variable-length patterns. Be specific 9[2-9]...... 91[2-9]..[2-9]...... and 9011T are more appropriate if in North America.
VIP Super Bronze
Thanks Jonathan, about 20 minutes after I posted I figured it out.  I added a dial-peer with the [2-9]... variable and it works fine.
Now to figure out COR stuff to keep them from dialing anything but internal extensions and 911.
559
