02-13-2012 12:19 PM - edited 03-16-2019 09:33 AM
I have a 7970 with an expansion module. I need to rearrange the order of the lines without changing the config.
It looks like I should be able to do this with "Modify Button Items", but it also looks like I am on a standard template "14 line 7970"
If I rearrange the line order and save the config, does this automatically create a new phone individual template and associate it with the mac-address?
02-13-2012 12:35 PM
If you use the modify button, it will create a new individual phone template. I do not recommand that, cause try to imagine what will happen when you have 15000 individual phone templates.
Try to remove the association between the lines and device profile for all extensions, and add them again in the order you want, keeping the Standard template.
02-13-2012 12:35 PM
Yes, cucm will create new template which you can later simply switch and delete.
Chris
02-13-2012 06:50 PM
Thanks again for being a big help Chris.
I was able to rearrange the lines and it created a custom template. But there is one line that was not there that needs to be added.
Basically this is a Manager phone and has all the other workers extensions configured as an additional extension on her phone.
As you can tell I am new to doing these things, so I am not 100% sure on what all needs to be done. I could just recreate the line by copying everything from the missing extension, but is this how it would normally be done?
Also, I see I need to associate the Managers phone (mac address) to the extension I am goingto add the the expansion module. Is this correct?
02-14-2012 06:56 AM
I am not following completely, create a template that matches the exact line/feature appearances for this phone type and assign it to the phone, if the template matches button functions everything will be preserved.
Chris
02-14-2012 07:36 AM
Sorry Chris,
I meant to update this before you had to post anything.
I found what I was looking for, I like your tip of creating the custom template, and just deleting it if it is no longer needed.
I re-arranged the numbers and saved and it created the custome template, but I needed to add an extension to the module that was not on there before.
I wasn't sure how to "associate" the users phone to the line on the expansion module. I found that once I added the line and selected the correct partition, everything else that was needed pretty much populated on it's own except a couple of line tags.
But, the line on the expansion module was associated with the phone.
02-15-2012 07:50 AM
Chris, I don't know if you saw my last post on this, but I mentioned that on the expansion module, on the line that I needed to add, all I had to do was enter the extension number.
Once I added the partition information, the line was associated to the expansion module and most of the fields were populated.
This would indicate that a line is a seperate entity unto itself and can be associated to numerous phones once it is created, is this correct?
Also, since it knew which line I was getting once I put the partition information in the config, then is it correct to say that you can have overlapping directory numbers in different partitions?
Although it could get confusing, is that possible?
02-15-2012 09:16 AM
That indicated you already have that line defined on another phone and it became a shared line, or that it was defined before and deleted and you have the auto popluation service parameter enabled.
Correct, you can actaully build lines without phones, see it under Route menu
See my first answer, the way to see if this is a shared line is to look under associated devices box on the DN to see if there are more than one device listed.
Chris
