1751 IS ABLE TO MAKE CALL OUT,BUT CANNOT RECEIVE ANY
Hi Pros,
I been doing some fexes over IP with cisco 1750.I've decided to you use 1751 now, I am able to place call to the PSTN from the 1751; however,calls from the PSTN deos not get to the router.
The route has IOS:12.3(2)T4 with Flash c1700-sv3y-mz.123-2.TB.bin....
there the actual config
hostname xxxx
logging buffered 20000 debugging
logging rate-limit console 10 except errors
enable secret xxx
no ip dhcp-client network-discovery
call rsvp-sync
voice class codec 1
codec preference 1 g729r8
interface FastEthernet0/0
ip address 10.7.7.170 255.255.255.0
no ip redirects
no ip unreachables
no ip route-cache
no ip mroute-cache
speed auto
full-duplex
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 f0/0
ip route 1.1.1.1 255.255.255.255 Null0
no ip http server
no cdp run
voice-port 2/0
echo-cancel coverage 32
timeouts interdigit 3
voice-port 2/1
dial-peer voice 200 voip
huntstop
preference 1
max-conn 1
destination-pattern .T
voice-class codec 1
session target ipv4:10.10.243.1
dtmf-relay cisco-rtp
playout-delay nominal 250
no vad
dial-peer voice 100 pots
destination-pattern 403451xxxx
port 2/0
scheduler allocate 20000 1000
end
AND THERE THE DIAL-PEER on getway to provide dialton
dial-peer voice 4510542 voip
huntstop
destination-pattern 4034510542
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target ipv4:10.7.7.170
playout-delay mode fixed
fax rate 7200
ip qos dscp cs5 media
no vad
Thanks in advance for your helps guys
VIP Super Bronze
Re: 1751 IS ABLE TO MAKE CALL OUT,BUT CANNOT RECEIVE ANY
what exactly is the problem you are having? What do you mean you caanot receive calls?
What call procesing agent are u using? CCM or CCME?
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
The problem is the router cannot receive any calls from the voice getway.However, it is able to call out using the same voice getway.
And I am not using CCM nor CCME.
Crazy
158
