1751 not able to receive call,but place outgoing call
Hi Pros,
I been doing some fexes over IP with cisco 1750.I've decided to you use 1751 now, I am able to place call to the PSTN from the 1751; however,calls from the PSTN deos not get to the router.
The route has IOS:12.3(2)T4 with Flash c1700-sv3y-mz.123-2.TB.bin....
there the actual config
hostname xxxx
logging buffered 20000 debugging
logging rate-limit console 10 except errors
enable secret xxx
no ip dhcp-client network-discovery
call rsvp-sync
voice class codec 1
codec preference 1 g729r8
interface FastEthernet0/0
ip address 10.7.7.170 255.255.255.0
no ip redirects
no ip unreachables
no ip route-cache
no ip mroute-cache
speed auto
full-duplex
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 f0/0
ip route 1.1.1.1 255.255.255.255 Null0
no ip http server
no cdp run
voice-port 2/0
echo-cancel coverage 32
timeouts interdigit 3
voice-port 2/1
dial-peer voice 200 voip
huntstop
preference 1
max-conn 1
destination-pattern .T
voice-class codec 1
session target ipv4:10.10.243.1
dtmf-relay cisco-rtp
playout-delay nominal 250
no vad
dial-peer voice 100 pots
destination-pattern 403451xxxx
port 2/0
scheduler allocate 20000 1000
end
AND THERE THE DIAL-PEER on getway to provide dialton
dial-peer voice 4510542 voip
huntstop
destination-pattern 4034510542
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target ipv4:10.7.7.170
playout-delay mode fixed
fax rate 7200
ip qos dscp cs5 media
no vad
Thanks in advance for your helps guys
VIP Super Bronze
Re: 1751 not able to receive call,but place outgoing call
If Calls are not getting to your router at all then you need to speak to your telco. That means that telco is not routing the call to your trunk.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
The calls from my Telco is getting to my PRI and I can see my PRI trying to reach the router with the fax machine on. And from this router, I call the PSTN fine.....
BTW, I took the same config and put it into a 1750.I am able to receive and send call with the SAME config with out ANY CHANGE!!
I think upgrading the IOS on the 1751 to see, whether the IOS is the problem...
Crazy
Silver
You edited your configs before posting so not sure if you just clipped this out, but I don't see an inbound dial-peer (i.e. "incoming called-number ."). Can you confirm?
Thanks you for your help, I got this fix by upfrading the IOS for the newest advanceipvoice ios.
Crazy
105
