1760 router with VIC2-2EM
I am having a problem passing audio from one 1760 to another. There is no keying or hooking involved. I need a dedicated always open 4 wire path. Any Suggestions would be helpful.
Hall of Fame Super Gold
Re: 1760 router with VIC2-2EM
are you familiar with the command "connection trunk" ? That will make the path be always open.
yes i am. How can I be sure that I am directing the port correctly
The once you configure the correct port under dial-peer, it will be OK.
158
