1760 - vic2-2BRI-/TE - vic-2FXO
Router 1760 ccme 4.1
IOS c1700-adventerprisek9-mz.124-15.T1.bin
slot0 WIC-1ADSL-I-DG
slot1 empty
slot2 vic2-2BRI-/TE
slot3 vic-2FXO
Hello, I am facing the following problem:
When I plug-in the vic-2FXO card I am unable to see (and configute) voice ports 2/0 & 2/1
I will appreciate any help.
Hall of Fame Super Gold
Re: 1760 - vic2-2BRI-/TE - vic-2FXO
Hi, send show diag. Most likely you do not have dsp resource and need to add the in the form of PVDM-256-XX modules.
Do a SH DIAG and check the type of DSP module you have installed in the router. I suspect you don't have enough DSP resources for the 4 B channels on the 2 port BRI and the 2 port FXO ports.
Paste the SH DIAG output here so we can confirm.
Hi all.
Seems you guys replied at the same time and made more sense to me as well.
Cheers ;-)
Thot.
Very Fast Replay!!!
Here is the show diag.
So now a race to give you the final answer :-)
You have a PVDM-256K-4= DSP module , which will only support 4 channels, which would be the 4 B channels of the BRI card, or the VIC-2FXO, but not both at the same time.
You will need a PVDM-256K-8= at the very least for this to work.
To understand DSP and hardware requirements , check out the DSP calculator on cisco.com -
http://www.cisco.com/pcgi-bin/Support/DSP/cisco_prodsel.pl
157
