1760 Voice gateway T1 CAS
I am trying to configure 1760 Router (ver 12.3.14T ) with T1-CAS as an MGCP gateway.
As part of MGCP configuration i am trying to run
"ds0-group 0 timeslots 1-24 type none service mgcp " , however this command doesn't seems to be supported on this router
VG(config-controller)#ds0-group 0 timeslots 1-24 type none service mgcp
% Invalid input detected at '^' marker.
I tried a couple of other IOS version without any luck. Did anyone configure 1760 as MGCP GW with T1-CAS ?
1 REPLY
Bronze
Re: 1760 Voice gateway T1 CAS
you will need to configure the MGCP service under the dial-peer command and not in the controller.
example
dial-peer voice 1 pots
destination-pattern
service MGCPAPP (some are case sensitive so do all caps)
port (T1 voice port created in the DS0-group)
the service MGCP under the controller is used when you configure a PRI-group i think.
128
