Community Member
2 cmes in 2 different locations
hi,
I have 2 cmes.
cme 2- in one location the cme has 41xxx extensions.
cme 1 - in another location the main cme has 2xx extensions with a sip trunk, auto attendant, voicemail...
I'm sending from cme2 all calls to 2xx and to outside world to cme1.
now when I call the main number on the cme1 and I try to dial the 41xxx number it says INVALID NUMBER.
any way I can make my cme1 know aobut cm2 numbes so calling the main number I can get hold of someone on cme2?
thanks.
Just configure the necessary dial-peers between them for that to happen.
On CME 1 a DP pointing to 41.. and on CME 2 a DP pointing to 2..
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
I already have that. this portion works.
what I want is when I call the main number on CME1 ex: 123 456 7890 and autoattendant takes over, when I try to reach a 41xxx extension it tells me INVALID NUMBER.
so: hello welcome to xyz if you know your parties ext dial it now.
if I do 2xx extension it works but if I do 41xxx it says invalid number.
Can you please attach your two CME configs.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
114
