2 instances of MOH
I am running CME on a 2821 and the customer is asking for two separate MOH files based on what number is dialed. I don't think this is possible, but thought I would ask.
Heath
1 ACCEPTED SOLUTION
Re: 2 instances of MOH
Within IOS you can only stream MoH audio to a single multicast address, therefore I cannot see it being possible to stream two separate MoH files.
Allan.
Allan.
Hall of Fame Super Gold
Are you using B-ACD AA?
If so, that could be doing playing a per-service custom music file to external callers in queue, instead of general MOH. That would not be possible anymore once the extension is reached.
I will consider this feature for a future modification to the script file, would you then be able to test ?
93
