Community Member
2 Separte Unity Cluster
I have a customer with 50 sites, and I have proposed 2 cluster design. (30)Locations in East CCM Cluster, and the (20) Locations in West CCM Cluster.
What would be the best option for Unity. Should I propose (1) Unity Cluster to support both CCM Cluster or a separte Unity cluster as for each CCM Cluster.
Bronze
Re: 2 Separte Unity Cluster
Well,
I suggest two separate Unity cluster for performance and redundancy if the money is not the problem. At least half of users wont affect if one of the cluster die.
Here is design guide for Unity:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/design/udg/index.htm
Also, you need to create Untiy networking (VPIM) between two clusters, so they can transfer voice mail between two cluster.
my 5 cents
Ken
Hall of Fame Super Silver
You did not specify how many user will be part fo these 2 clusters, but I agree that 2 Unity environemnts will make most sense. Also, you want to implement Digital Networking not VPIM networking between these Unity environments.
Chris
Bronze
ooohs... my bad, thanks for correct me..
Ken
122
