2600 VWIC-1MFT-E1 back to back connection
Can anyone confirm weather it is possible to connect two 2600 back to back with the VWIC-1MFT-E1, wanted to look at simulating voice services over PRI connection, both routers will act as back to back H323 gateway.
Bill
3 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: 2600 VWIC-1MFT-E1 back to back connection
absolutely doable, configure clock internal on one side and line on the other. isdn network side on one and user on the other.
To illustrate what Paolo mentioned above.
R1
controller e1 1/0
clock source internal
pri-group timeslots 1-6
framing <>
linecode <>
int s1/0:15
isdn protocol-emulate network
R2
controller e1 1/0
clock source line
framing <>
linecode <>
int s1/0:15
isdn protocol-emulate user ### default config
Bill,
For 2600XMs you will need
a. Nm-hdv with pvdm12
b. nm-hdv2 with pvdm2-x (x=8,16,32,48,64)
Sankar
PS: please remember to rate posts!
R1
controller e1 1/0
framing <>
linecode <>
int s1/0:15
R2
controller e1 1/0
clock source line
framing <>
linecode <>
int s1/0:15
Thanks for the response.
I was also wanting to test call manager express with the VWIC-1MFT-E1 to setup back to back connection.
I noticed that the 2600 does not have onboard DSP capability how will the router manage DSP as the VWIC-1MFT-E1, do I also need to add an NM module with DSP.
Bill
Bill,
Sankar
458
