2610 E1 delay issue
I am currently trying to link a PBX using a Sangoma A101D E1 card to an Alcatel 4400 PBX.
At the moment both PBX's are in different physical locations so I have 2 Cisco 2610XM routers at each end allowing the link to be passed up a fibre.
Each router has an NM-HDV along with a WIC-1MFT-E1.  The NM-HDV has 3 PVDM-12 SIMM's in each router.  I am running IOS 12.4(17) IP VOICE
The system works fine at the moment, can hold calls, ring both directions etc without problem but my issue is that there is a slight voice quality issue (degraded and hissy) and roughly a half second delay in speech.  This is quite noticable when in a call.
I am therefore not sure whether its a configuration issue or a hardware processing problem.
A point to note is that I have taken the PBX with the Sangoma card and plugged it directly into the Alcatel PBX and the voice quality is crystal clear with no delay.  I have also changed fibre's, converters etc but there is still a delay when passing the E1 through the routers.
The delay is definatly being added during the routing phase.
Can someone advise please? - I'm honestly thinking its due to the age of the hardware, if so, can someone recommend replacement hardware?
Here is my config (i have cut out passwords etc):
Alcatel end:
version 12.4
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname 2600_A_ALCATEL
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
voice-card 1
ip cef
no ip domain lookup
isdn switch-type primary-qsig
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 3 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g711ulaw
fax interface-type fax-mail
controller E1 1/0
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 10.0.0.50 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn timer T203 30000
isdn timer T310 60000
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
router rip
network 10.0.0.0
no ip forward-protocol nd
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
no cdp run
control-plane
voice-port 1/0:15
dial-peer voice 1 voip
destination-pattern 20..
voice-class codec 1
session protocol sipv2
session target ipv4:10.0.0.51
session transport udp
dial-peer voice 5 pots
destination-pattern 9.+
direct-inward-dial
port 1/0:15
prefix 9
Sangoma PBX End:
version 12.4
hostname 2600_B_VOIP
boot-start-marker
boot-end-marker
no aaa new-model
voice-card 1
ip cef
no ip domain lookup
voice rtp send-recv
voice service voip
voice class codec 1
controller E1 1/0
ip address 10.0.0.51 255.255.255.0
duplex auto
speed auto
no cdp enable
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
no ip http server
no cdp run
control-plane
voice-port 1/0:15
dial-peer voice 1 pots
direct-inward-dial
port 1/0:15
prefix 20
dial-peer voice 5 voip
voice-class codec 1
session target ipv4:10.0.0.50
Hall of Fame Super Gold
2610 E1 delay issue
As you say - the 2600 is seriously obsolete to not even bother with.
Move to a 2901 and you shall be finbe.
2610 E1 delay issue
as i thought! - Thank you
Which modules would be compatible (modern version of NM-HDV and a WIC-1MFT-E1) with the 2901?
Re: 2610 E1 delay issue
You can buy an UC bundle and then depending on the number of channels, just add a VWIC E1.
Please remember to rate useful posts clicking on the stars below.
269
