2621xm - SIP registration & fxs issue
Hello all,
I've been setting up a 2621XM with the purpose of connecting a SIP trunk to an FXS port to make/receive calls.  I have everything working, save for these last two issues I've come across:
  1. The router is successfully registering to the SIP provider.  However, the configuration necessary to have the FXS port to ring (dial-peer 3001) is also causing the router to try and register against the SIP server with that number (1011) as well.  Is there any way to prevent this?
  2. Incoming calls work fine -- the FXS port rings and conversations can occur.  However, when the remote party hangs up -- the FXS port does not go back on-hook.  How can I ensure this happens?
Config attached; any help greatly appreciated.
Thanks!
-Matt
201
