2801 - ccme.html - does it exist?
As above, can I access the web config part by using the above address on my 2801? I try it but IE just says 'done' and displays a blank white screen.
Re: 2801 - ccme.html - does it exist?
You need to flow through some additional steps to be able to use the GUI. I have posted below a guide to help you through enabling the gui.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html
I'm experiencing the same issue.  What was the resolution?
Hall of Fame Super Gold
The one given above.
Or, you may be using the wrong version GUI files for the running IOS.
How do I verify if I have the wrong version?
Here is a debug from an attempted login.
Oct 11 17:10:40.979: its_urlhook url: /ccme.html, method 1
Oct 11 17:10:40.979: Mon, 11 Oct 2010 17:10:40 GMT 10.0.0.88 /ccme.html auth_req
uired
        Protocol = HTTP/1.1 Method = GET
--More--
Oct 11 17:10:46.971: its_urlhook url: /ccme.html, method 1
Oct 11 17:10:46.983: HTTP: Priv level granted 15
Oct 11 17:10:46.983: Mon, 11 Oct 2010 17:10:46 GMT 10.0.0.88 /ccme.html ok
Oct 11 17:10:46.987: telephony_service_server_get_action url:/ccme.html
Here is the IOS.
flash:c2800nm-adventerprisek9_ivs-mz.124-22.T5.bin
You need to download the files specific for your version.
Anyway, the GUI is next to garbageware, so you're not loosing much.
Appreciate it.  I agree about the gui, however this is for lab purposes only.
Even though you won't be able to see ccme.html file on the flash but it would still work.
I had same issue. However I was able to fix it.
First, make sure you have the correct files extracted. Use this command:
archive tar /xtract tftp://xxx.xxx.xxx.xxx/file.tar flash:/
Secondly, make a note if you created a folder on flash and put the GUI files on there? If you did that, you will have modify ip http server command on the router.
I extracted the files to this folder on flash:
Flash:CME8.6.0GUI
So I modified the ip http command to:
ip http path flash:CME8.6.0GUI
Then it should work.
1523
