2801 cme download
I recently purchased from ebay a 2801 router that is voice capable.  I have also purchased a couple of phone.  How can I download CME on this router to play with it?  It is running 12.4
2 ACCEPTED SOLUTIONS
2801 cme download
Joli,
If you meant how to enable the GUI for CME then please refer " Enabling GUI " section.
GP.
Pls rate helpful posts by clicking on stars below the post !!
Hall of Fame Super Gold
2801 cme download
IOS 15.1(4)M, CME 8.6
Please remember to rate useful posts clicking on the stars below.
2801 cme download
If it is running a voice or greater image, CME is already embedded in there.
Otherwise, most downloads on cisco.com require a paid support contract.
Re: 2801 cme download
Try running the show telephony-service command.
If it show an output like the following it means that the GW is running an image that has the feature enabled.
CONFIG (Version=8.1)
Version 8.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
(output ommited)
If it says that the service is not enabled try enabling it by running the commands below:
conf t
telephony-service
I was able to enable the telephony-service, now how can I enable the web server to configure the call manager?
2801 cme download
Joli,
GP.
2801 cme download
I followed the steps to enable the GUi but the gui shows up blank.  and when I do a sh flash it just shows the current ios and not files.
2801 cme download
2801 cme download
to download this will I need a subscription or can I just purchase it?
2801 cme download
downloading software is always charged process but if your CCO ID already has the support contract associated with it, then it's free for you. Try logging in to the page & if you are able to download it then it means you have the necessary contract associated & you can download multiple softwares as many time as you wish from CCO
GP.
Pls rate helpful posts !!
2801 cme download
nope my id doesnt have access to it. but thx anyways.
2801 cme download
my router is running version 12.4(13r)T.  What is the latest version of CME that my router will support?
2801 cme download
2801 cme download
If your ISR has already a CME flavor you can do all the config via CLI, you do not necessarily need the GUI.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
2733
