2801 - installing a vwic21mft-t1/e1 - what slot?
Hi. I've got a new 2801 here and an interface card for it. Now i've got 4 available slots for it, but im sure I read somewhere that if I put this vwic2 card in one of the slots I could damage it.. but I cant find that document now grrrr.
What slot should i go for ?
Thanks! :)
Hall of Fame Super Gold
Re: 2801 - installing a vwic21mft-t1/e1 - what slot?
It's written on the back of the router. Slot 0 is voice only.
Silver
I currently can't find the doc myself but if I remember correctly doesn't it tell you on the front of the router itself what card you can install in each slot? i.e slot 0 VWIC, slot 1 FXO-FXS.
well what ive got is:
Slot 3 nothing written on it
Slot 2 Only VIC's and WIC's
Slot 1 nothing written on it
Slot 0 Only accepts VIC's
As my card is a VWIC 2 not sure what one I go for
on 2801 router all the slots supports VWIC module.
So you can install it on any of the slots.
• 4 slots; 2 slots support HWIC, WIC, VIC, or VWIC type modules
• 1 slot supports WIC, VIC, or VWIC type modules
• 1 slot supports VIC or VWIC type modules
-> Sushil
ah ok, well i've slotted it into slot 3. However it doesn't show up when I run the show interface command
can you let me know the IOS file name you are running.
you should have minimum IP Voice.
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(9)T7, RE)
System image file is "flash:c2801-spservicesk9-mz.124-9.T7.bin"
can you paste the show diag outpu.
Silver
Ah, you're using t1/e1. You need to configure the card type
global config>card type e1
If you're running 12.4 spsvcs this should work
can you pleae check if you have PVDMs on the router.
I've put the card in slot 2.
I've entered the command:
card type e1 0 2
and th LP light lights up green or half a second, then the AL light is amber.
WIC/VIC Slot 2:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC12021G7S
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 32 30 32 31 47 37 53 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
card type e1 0 2
515
