2801 VGW with MGCP & H323 Configuration EXP with Redundancy
I want to configure 2801 VGW with MGCP or H323 Protocols for CCM 4.1.3
As I have (2) 2801 VGW I need redundancy as if failure occurs in one VGW with PRI the 2nd one takes charges with 2nd PRI configured, also I have 2 PRI for redundancy
As happens in CCM, if PUB goes down SUB takes charges and IPT works fine
Re: 2801 VGW with MGCP & H323 Configuration EXP with Redundancy
I understand that you have 2 Voice Gateways, you can configure your first PRI as the MGCP Gateway on the First Router and the second MGCP Gateway on Second Router. Configure these gateways as part of the Route Group in order and then configure the Route List to include the Route Groups, then configure a Route Pattern and point to to the Route List to route the calls. This should help you to build the redundancy.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_2/srnd4_2/uc4_2/42gatewy.htm
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed675.html
Please do keep in mind that it is important for you to consider the redundanct at LAN and connectivity to ensure end to end redundancy for complete failover incase of any failure in the call path.
Thanks & Regards,
Sriharshaa Prabhakar
Senior Network Engineer
________________________
Computer Network Systems
P.O. Box: 46144, Abu Dhabi, UAE
Tel :( +971-2) 6442888, Ext 2411
Mobile :( +971-50) 5212956
sriharshaa.prabhakar@cns-me.com
Thanks for your reply
I will check and get backs to you
Thanks very much for your reply and guidance
Execuxe me for a late reply
Kind Regards,
Fawad
144
